Hey all, i have a RICHO Aficio SG 3110DN printer that i use for sublimation along with a 3D ST3042 heat press.
On the Ricoh support web site there are two sets for drivers, both the same driver version and both the same release date. How would i know what drivers i am meant to be using for best sublimation results? Anybody here own a RICHO Aficio SG 3110DN printer for sublimation? if so what drivers from the website did you choose?
Thanks.
Aficio SG 3110DN driver?
Re: Aficio SG 3110DN driver?
What inks are you using? If Sawgrass go to their website and download the powerdriver. If you are using something else your supplier should supply you with an ICC profile.
If this is all new to you may I suggest you have a good look through this forum and you should find all the answers.
The drivers are here:ATOJAR;122736 wrote:Hey all, i have a RICHO Aficio SG 3110DN printer that i use for sublimation along with a 3D ST3042 heat press.
Thanks.
http://support.ricoh.com/bb/html/dr_ut_ ... 3110dn.htm
I'd suggest the latest driver (top one) to get the printer installed first. Then you need to download and install the PowerDriver from either the USB stick supplied with your first set of inks or direct from the Sawgrass website.
The ink is from city ink, I got a disc with ICC profiles on but I'm not sure what profile I'm suppose to use with photoshop CS6.
Anybody got any advice please?
Thanks.
Thanks.
