Hi All
I am having a clear out of kit that I had stashed away for a rainy day - its been drizzling steadily for some weeks its time to make some room and raise some funds for other projects. I have loads of stuff to dispose of but these are probably the most relevant to other users of this Forum.
I have a pair of single phase Compair Easyair E10 compressors. 100 litre x 150psi tank, vertical twin piston pump with fresh oil in, pressure cut off switch fitted. These compressors have been unused for at least 10 years - dry stored. They were the emergency back up in a well maintained plant room and consequently were hardly used. The nearest thing I can see to these in Macine Mart is a Clarke compressor that weighs in at over £400. Secondhand the 2HP motor fitted to each compressor is worth £30 or £40 on its own.
They are for sale individually for £100 each but I would do a deal if anyone wanted them both. They can be seen 2 minutes from J13 of the M11 in Cambridgeshire. They should fit in the back of an estate car. It MAY be possible to deliver them locally at cost price otherwise they would have to be collected in person.
They are advertised eleswhere at
http://www.homeworkshop.org.uk/images/c ... 29578a.jpg
http://www.homeworkshop.org.uk/images/c ... 29578b.jpg
Where there are images of one of the compressors - the other one is near identical except that it is red
regards
Dudley
compressor
