Hi All, Have just purchased from Ebay a Ricoh SG3110DN...when I power it up it displays waiting then runs what sounds like a cycle...and says low ink..then it repeats then repeats and repeats and keeps saying waiting...
any help greatly appreciated
Sg3110dn
Re: Sg3110dn
What inks are in the printer? Subli or normal?
Do you need to do an initial fill on the Ricoh? I can't remember.
stevenson166
Re: Sg3110dn
Apologies all. I have been a seasoned forum member elsewhere and realise now that spending a bit of time starting a thread generally results in people spending a bit of time helping. The Ricoh was used and has sub ink in. The waiting message was because the machine was undergoing its start up procedure. It was plugged in straight from the box after delivery and just by opening the print cover and making sure all inks were securely attached solved the problem. Again apologies
