Adkins: How many mugs do you get out of an element?
Alburt
Re: Adkins: How many mugs do you get out of an element?
Post by Alburt »
Hey, I'm interested to see how many mugs people are getting out of their elements? The company that sold me my press had advised around 300+ but I've read on this forum some people mentioning 1000s.
Having gone through a few elements in the past without noting how many mugs they produced, I've started keeping a tally to record. Currently sitting at 570 presses with the current element since December (On an Adkins solo press at 190oC for 150secs) but since the 540th mug its started to randomly (not every single mug but the majority) leave a very faded section at the very, very edge on one side near the handle. Its feels as if the end of the press isn't getting the same heat it did for the first 500+.
I guess I have a couple of questions:
Is fading like that at the edge after so many mugs a sign that the element is gone, or is it more likely the pressure/ heat is the issue. I tried increasing pressure as a test and got another 10 good mugs but its started to produce the fade again already, all mugs printed this morning are rubbish. I don't think I can increase the pressure any further and actually get the mug into the press now. (Pressure is still high, ie the press closure is almost toughing the handle now, wish there was a more accurate way to set the pressure.)
Second question, as time goes do you need to increase/ decrease pressure?
Just wanted to get people's thoughts before I swap out the element for a new one.
Thanks for you help.
Allistair
JMugs
Has thanked: 9 times
Post by JMugs »
I had over a 1000 out of my last adkins blanket, I did post here somewhere how many it was.
I think pressure is a factor in killing blankets. The pressure only needs to be enough to press the paper against the mug to stop blow out. Hence my pressure is relatively light. The more pressure the more the heating elements flex, the more they flex the more they weaken and the quicker they break......I think!
No scientific research carried out by my there so it could be complete rubbish!
Janners
Alburt
Post by Alburt »
Thanks Janners, 1000+ from an element sounds great value for money
Your theory on what affects the extent of a blanket's life sounds good to me. Wish there was a more scientific method for applying the correct pressure other than a purely by eye judgement.
As a test I've just tried lowering the pressure to below where I would normally have set it and I tested on an old mug. First time print was perfect. Tried again and again, and again and sadly every other attempt since has had a slight fade on the left edge. A mystery. Think I might need to bite the bullet and ditch the element.
Good to know it is possible to get over 1000 though. A target to aim for with this new element.
Allistair
