Company? Heat Press Direct
iceviper
Re: Company? Heat Press Direct
Post by iceviper »
Hi was just wondering if anyone has dealt with Heat Press Direct. Prices appear to be reasonable and they offer a 12 month rtb warranty but wanted to see if anyone has dealt with them https://www.heatpressesdirect.com They have a new 38x38 press for around the 300 mark. Its either that or I have the possibility of a second hand stahls also for 300 but it has no warranty. Any Thoughts welcome. As you can tell i'm very new to all this. I'm itching to take the plunge but am collecting a mass of research first. Mainly thanks to this forum making life much easier.
Following this thread as there is a machine on there that I have been looking at for a while...
I bought my 5-in-1 setup from them. Good presses with even temperature distribution. I've printed mugs, aluminium plate up to A4 size, jigsaws etc and had no real problems.
iceviper
Post by iceviper »
webtrekker;120778 wrote:I bought my 5-in-1 setup from them. Good presses with even temperature distribution. I've printed mugs, aluminium plate up to A4 size, jigsaws etc and had no real problems.
Thanks webtrekker. Have you had the equipment long?
Post by GoonerGary »
socialgiraffe;120777 wrote:Following this thread as there is a machine on there that I have been looking at for a while...
Fiver says it's the lanyard press.
Yep, although I do think it is funny that he advertises it as a Lanyard Press and shows you how to press a tie :-)
I might want it for something completely different though....
iceviper;120779 wrote:Thanks webtrekker. Have you had the equipment long?
I've had it for over 7 months now. I've not had a use for the cap or plate presses yet, but the mug and swing-away presses have been fine.
iceviper
Post by iceviper »
Excellent. Thanks for your help 👍
Sent from my F3111 using Tapatalk
