Sizing Coreldraw & Vesaworks
Focus1
Re: Sizing Coreldraw & Vesaworks
Post by Focus1 »
Hi,
I was trying to get an image sized at H: 55mm and W: 55mm in Corel Paintshop Pro X7, the dimensions changed to 54.63mm and 54mm. I transferred the file to Roland VersaWorks and the sizing was still 54.63mm and 54mm. When it was then sent to the Roland-20, the measurements came out at 46mm not 55mm. I tried to reset the sizes over and over again but it still comes out on Versa at 54.63mm and prints at 46mm. The only way that I can get the sizing is by adding 8mm onto the image size.
Can anyone advise how to set the image at 55mm and for it to be 55mm when printed. Or can anyone advise why this keeps happening.
Ravisteam
Post by Ravisteam »
I am also new to VW and similer thing happened to me ...you have to set the print size on Corel (where u select the printer and other print options )select the custom size and give the exact size of the job .then only it worked for me ...
