Yes or No
BillyG
Re: Yes or No
Post by BillyG »
I have the Ricoh SG 3110DNw an I have read somewhere that it should be left on all the time for Maintance reasons is this true or not Thanks BillyG
Re: Yes or No
We have multiple Ricoh's and they are put to bed each night and woken up when needed. Even after a three week shut down last year then they worked perfectly when woken from their slumber.
willd
Re: Yes or No
Post by willd »
We've found with ours that if switched off for a period of time it does a cleaning cycle every time it is powered up. If left switched on, although it wakes up periodically, it runs a cleaning cycle much less frequently. If you use Sawgrass ink I'd guess that the ink saved pays for the standby electricity consumed many times over...
Re: Yes or No
If you do a few prints a week then turn it off, if you use it everyday then I would recommend leaving it on.
I suppose it all depends on the amount of use, I leave mine on unless I go on holiday, but then it works quite hard everyday of the week.
logobear
Re: Yes or No
Post by logobear »
we leave ours on all the time. used about 4 days a week. think we avoid startup cleaning cycles, so save on ink, but not that sure .....
BillyG
Re: Yes or No
Post by BillyG »
I thank you all I will just leave it on. Sure does make A lot of noise when printing. BillyG
