what printer is the best for sublimation
philphil123
Re: what printer is the best for sublimation
Post by philphil123 »
hi im just wondering if any of you have had any experience with any of these 2 A3 sub printers any info would be grateful and advice on what 1 to buy
epson 7110DTW
epson 1500W
[h=1]thanks[/h]
Loads of threads discussing this. If you need the additional colours the 1500 has the edge, if you want an easy route to market the newer Ricoh take some beating.
philphil123
thanks i have searched but couldnt see ill look abit better also what is the new ricoh model ill look at that
thanks
Remember the similar threads box above your threads, can sometimes help. Newer model is SG800....I think!
If you have budget then SG800 (before prices go up) otherwise buy 2nd hand SG7100DN. In our opinion.
Post by GoonerGary »
Will you printing photographic images or mainly text? If text, go for an office type printer as this should provide sharper text...the Epson 7110. The 1500W is marketed towards amateur photographers so should lean towards giving better graduated colours.
pw66
Post by pw66 »
There have been some problems with the T27 refillable cartridges, that go into the 7110, not working properly recently. There was a long thread on it over on the T-shirt Forums site recently. Admittedly it was in conjunction with a 7610, but the cartridges are the same.
At less than £200 the 1500w looks good value for money. You will get £35 back on the ink set, if you sell them on ebay.
malkram
Post by malkram »
Better keep the ink set because you will need it if one day you need to bring the printer for repair
James990
Post by James990 »
1500w all the way for me, complete with a CISS!!
philphil123
thanks for your responses i have ordered the 1500w
here http://www.ebay.co.uk/itm/381585120123
and james990 do you have the 1500w
cheers phil
