Adkins Beta Maxi Heat Press 20 x 16 - One of the older/better ones!
Re: Adkins Beta Maxi Heat Press 20 x 16 - One of the older/better ones!
I'm selling my trusty Adkins swing away heat press. After careful consideration I can't justify having it sat here as a backup machine so go it must!
It's a July 2005 model. Anyone who doesn't already know about these presses....The older machines were UK made and are superior to the newer presses. Newer presses are still excellent but are only 'put together' in the UK. They currently retail with Xpres for over £1300, £1495 on eBay! Newer presses have the darker gray upper platen, older ones the platen matches the rest of the machine. These don't come along very often and hold their price very well.
It's in overall excellent used condition and has been very well looked after. The display has a very slight issue in that 1 of the led bars is out. This makes no real difference and you can still see the time/temp clearly (see attached pics) but I wanted to be completely honest :-)
This is the larger 20" x 16" machine with quick release lower beds. One of the drawbacks, if not the only drawback with these presses, was that they didn't open/lock wide enough for thicker blanks, 20mm acrylic for example. I have made a slim bed that replaces the lower bed quickly and allows thicker items to be pressed. I'll include this along with a new cushion pad if postage isn't too bad, it's very heavy!
This machine weighs over 50kg packed (excluding above bed!) and very unusually I have the original box and packaging.
Selling for £500 and would prefer if you can arrange courier collection yourself from Aberdeen with a courier. I can sort this but will need to double check prices once packaged.
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4440
vB_ID:4439
vB_ID:4439
vB_ID:4438
vB_ID:4438
vB_ID:4436
vB_ID:4436
vB_ID:4437
vB_ID:4437
Sorry, just marking as sold as it's gone.
