Slow down Ricoh 3110
Jerry
Re: Slow down Ricoh 3110
Post by Jerry »
I get strong banding of solid colors (light 2mm horizontal) when using the quality-priority/inkjet-paper mode. This is a speed issue. Is there a way to manually slow the printer down?
No, you need to install the correct profile for the inks you are using and this should adjust the speed accordingly.
You could try selecting a thicker paper or glossy, but that will result in using considerably more ink.
Are you using Sawgrass ink?
