Paper size for mugs
Disky
Re: Paper size for mugs
Post by Disky »
Was talking to someone today that does mugs and sells them on Facebook..
she he was telling me that she's fed up with wasting so much sub paper and when I asked what she meant, she told me she used 1 sheet of a4 sub paper for each image, unless she was doing a larger run,then she would get 2 out of an a4 sheet.
i only buy trupix paper now, but I have a mate that's a print finisher and he guilotines the a4 down to 210x99mm for me so I get 3 mugs out of every sheet.
does anyone else do that, or is it just me
willd
Post by willd »
We print 3 to a sheet then guillotine them :-).
Less wear on the printer that way...
scotty44
Post by scotty44 »
As above, 3 on a sheet then cut....
James990
Post by James990 »
I thought everyone did 3 to a sheet of A4 for ordinary mugs?
... or 10 across a strip of 44" roll paper! ;-)
calvinabc
Post by calvinabc »
i dont really know what to say?????!!!!
Not me, I only get two to a sheet as I have my paper pre-cut to 235 x 100mm
Might need to get a wide format soon as that will save the pennies
Adrian B
Post by Adrian B »
We generally only get two designs on a single A4 sheet as we like to get the paper close to the mug handle. Some smaller designs do actually allow three to a single page but if we are in a hurry they often still get printed off as two to a single sheet.
paul 44
Post by paul 44 »
3 to a sheet for me to, you can save the paper and adjust accordingly from within the paper feeder but if its a large run then 3 to a sheet always as I know I will use them and i'm not wasting paper, 8 inches by 3 inches per print is what I use and can get 3 of those to an A4 sheet
