making your own wood blanks.
BillyG
Re: making your own wood blanks.
Post by BillyG »
Does anyone make there own sublimation blanks. I have painted A board snow white and sprayed it with Polyurethane has anyone done this and what were your results. Thanks for any help or A way to make my own blanks I would like to make 6 and 8 in wood clocks. BillyG :smile:
Maybe look at changing the way you want to do this. Rather than sublimation, you can use transfer papers which can be printed onto (inkjet/laser) and you then use your heat press to bond to substrate e.g. wood
If you have colour laser then try http://www.yolo.co.uk/techni-print-hard ... 9125-p.asp
If you have inkjet then try http://www.yolo.co.uk/jet-pro-sofstretc ... er-2-p.asp
You will need a flat substrate surface and of course ask for some trial sheets first (free if you become a premium member on this forum and then 15% off all items when you purchase!) in case the above process is not good enough for your needs.
Mugshots
Post by Mugshots »
How do you go about getting the free trial sheets?
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Errrr..........ask?
I have always found suppliers happy to send out trial stuff, some charge for postage, somee don't.
Janners
Mugshots
Post by Mugshots »
I saw the 3 sheet trial and didnt know if we as a forum had a code to apply o
In the code box.
I was recalling Yolo talking about it on this forum a while back. Send Yolo Creative a PM asking if they will supply you, a DSF premium member, a couple of trial sheets. Apologies as well as DSF discount is 10% which makes their 20% off at the moment very tempting.
