Full wrap mug
mrmarecek123
Re: Full wrap mug
Post by mrmarecek123 »
Hi ,
I need a picture to be able to see from both sides and front as well, so three different positions of mug .... (i will be changing this picture and background so I believe needs to be psd format.
See picture please
Is there anything how I can achieve this ? Please bear in mind my Photoshop knowledge is very basic at the moment. I am happy to buy it if there is no other way.
Regards
vB_ID:4291
vB_ID:4291
Re: Full wrap mug
You could use the mug script, it would show 3 mugs in different poses. I can't post example right now, someone will probably beat me to a pic.......
Re: Full wrap mug
You could visit a site such as Printful that has a mockup generator and simply upload your wrap artwork then download a zip file containing all the views for 11oz and 15oz mugs.
The files are in transparent PNG format so that you can easily drop in any background you like, as in my example below ...
(Er, I know, the perspective is all wrong, but it was just a quick demo lashed up in a couple of minutes. You can have whatever background you like).
vB_ID:4294
vB_ID:4294
vB_ID:4294
vB_ID:4294
vB_ID:4294
vB_ID:4294
vB_ID:4293
vB_ID:4293
vB_ID:4292
vB_ID:4292
Re: Full wrap mug
You could also easily place all 3 views together, on any background ...
vB_ID:4296
vB_ID:4296
vB_ID:4296
vB_ID:4296
vB_ID:4295
vB_ID:4295
Re: Full wrap mug
Graphic River has templates for Photoshop that are really easy to use and are very cheap to buy, you could also try Paul who has a mug visual generator that might work for you.
mrmarecek123
Re: Full wrap mug
Justin could you just explain what exactly do you mean please?
Webtrekker yes this is something what I am looking for but how much I can rely on this website ...... ? I would like to own it :)
Thank you guys for your help.
Re: Full wrap mug
socialgiraffe;116925 wrote:Graphic River has templates for Photoshop that are really easy to use and are very cheap to buy, you could also try Paul who has a mug visual generator that might work for you.
Ye, SG, I've had GraphicRiver stuff in the past and there's some really good stuff out there for next to nothing.
https://graphicriver.net/item/mug-mocku ... ?s_rank=23
https://graphicriver.net/item/mug-mocku ... ?s_rank=14
https://graphicriver.net/item/mug-mocku ... 6?s_rank=1
https://graphicriver.net/item/mug-mocku ... ?s_rank=16
https://graphicriver.net/item/coffee-cu ... ?s_rank=10
mrmarecek123
Re: Full wrap mug
webtrekker , socialgiraffe just to make sure do i need extended licence or regular ?I believe extended ........
Re: Full wrap mug
Re: Full wrap mug
mrmarecek123;116957 wrote:webtrekker , socialgiraffe just to make sure do i need extended licence or regular ?I believe extended ........
I would have thought a Regular licence as the 'end product' is simply an advetisement and, as such, is not in itself being sold. The items you will be selling are mugs, and the design for the mugs isn't being done with these 3D templates.
