metal key rings
Re: metal key rings
Hi! I got some key rings samples came last night and decided to have a go with them as I never try them before. I pressed 2 @ 195C for 50sec. and both come out FANTSTC! I am so impressed with them... So now is the question. what you use to hold insert in place? double sided sticky tape? glue? I wish to use something that can last for months but donk know whats good enough.
thanx
THE METAL MAN
Re: metal key rings
Post by THE METAL MAN »
hi paul
I USE DOUBLE SIDED TAPE AND NO BOTHER
adlindsay
Re: metal key rings
Post by adlindsay »
I used superglue on them. The one I use every day fro the last couple of years is looking a bit shabby and chipped now but the metal insert is still in place.
Hope this helps
Andy
JSR
Re: metal key rings
Post by JSR »
The ones I recently got from BMS have the sticky tape already in place.
Re: metal key rings
thanx guys! i bought some super glue. I also sprayed them with some varnish to give them extra life :)
