Black sublimation mugs
paul 44
Re: Black sublimation mugs
Post by paul 44 »
Does anybody know of a supplier of 11oz black sub mugs (not with white patch) at a reasonable price?
Cheers
Quinsfan
Post by Quinsfan »
Can I ask how you would sublimate onto black? Sorry no help in your quest though!!
Simple answer - unless it is a WOW mug (colour changing from black to white) or has a white patch then there is no such thing as a sublimation black mug. BUT we are playing around with regular black mugs (not sublimation) and using a silver/gold transfer foil that means you can print one colour (silver/gold) onto black mugs. Requires laser printer and special transfer paper.
paul 44
Post by paul 44 »
I have a customer that is looking for black mugs and thought i'd ask the question on here. The print is a silver print with a black background but he needs the entire mug to be black (inside and out) which I haven't printed on before?
Black mug
http://www.tesco.com/direct/plain-stone ... d=122-2346
Silver Paper
http://www.forever-ots.com/transfer-pap ... egory_id=1
Print 100% black onto paper using laser (needs toner) and then heat press onto mug. We haven't mastered perfectly yet so buy a little more than needed of course.
anniecov
Post by anniecov »
The main problem with these mugs is longevity. We trialled some black mugs (expensive!) with our white toner printer and followed all the instructions from TMT. They looked great until they went in the dishwasher. The image was coming off after a few dishwasher cycles. TMT say it will last up to 50 dishwasher cycles. Not brilliant compared to dye sublimation! I decided against stocking them.
These mugs would be fine for souvenirs that are never used but most people will want to use them. :wink:
Why don't you want to use the sublimation mugs with the white patch/window?
Post by GoonerGary »
Does it transfer completely without any missing bits? What problems have you encountered?
The white patched mugs will look odd because you can't match your black print with the black mug.
Earl Smith
Post by Earl Smith »
Have you looked at the mugs with a black handle and black inside? The whole of the outside of the mug is white and can be sublimated.
Just been posted by Listawood.
Listawood
Post by Listawood »
Hi Paul,
We have the following Black TwoTone mugs which I think would be a suitable option.
http://www.listawoodtradesupplies.com/i ... SMU&pgnum=
These are charged at £0.90 per unit exc VAT and shipping. These mugs will enable you to print a full colour design to the outside of the mug as well as the black handle and inner.
if you have any questions regarding these mugs then please do ask.
Mel
