Anyone know of a mug press that can take 22oz beer steins?
MREDD
Re: Anyone know of a mug press that can take 22oz beer steins?
Post by MREDD »
Hi All
This has been posed sometime ago but with no clear answer so I am revisiting the question.
I sell the new style 22oz beer stein from Coralgraph, the one with the gold line top & bottom. The only press I have found that gets anywhere close to accommodating them is one from BMS which is part of one that forms part of the DF18 combo kit.
But even that one is a struggle, I got a replacement from them about six weeks ago & managed to shatter the bolt that holds the framework together on the very first use with it. The 22oz steins measure 85mm as opposed to 80mm for a standard coffee mug, that 5mm difference is a big problem.
Coralgraph say that a model called a MP160 will take them, but Signzworld disagree & say 11oz is the max for that press. So does anyone know of a horizontal mug press that the clamp will open wide enough to accommodate them?
Regards
Ed
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
I have a couple of BMS mug presses DF1 (not the combo ones) and they fit in there easy enough.
Janners
