I have a small job, 1 shirt which is red and white, advised the customer of possible pitfalls ie print marks and possible color fade on the red part of the shirt.
I have the option of using mdp flex or flexcut sticky from yolo, both set at different temps (mdp at 150c and flexcut at 115c)
I am trying to minimise the press marks on the shirt and was going to use flexcut sticky but this is primariy for nylon material and it sets at 115c, according to the manufacturers spec, it is for dance/sportswear etc.
I have tried it on a 100% poly football shirt of my own and it seems ok but thinking of whether when its washed it will peel from the garment or not?
Anybody else used flexcut sticky nylon on polyester garments, good or bad?
thanks
100% poly football shirts
