Ricoh 3110 which ink for garments?
Maruci
Re: Ricoh 3110 which ink for garments?
Post by Maruci »
hi I bought a Ricoh sg3110 and I intend to use it to heat press garments only (tshirts); As sublimation ink only work in polyester (more expensive) and in light color tess and I am willing to use cotton (cheaper) and also in dark color tees too,which ink should I use Dye based ink or Dye pigment ink? can I find these inks for Ricohs? so far have only seen them for epson. by the way I have refillable ink cartridges. many thanks
Has thanked: 11 times
You do realise you can't print directly to dark tees and would need some kind of transfer paper?
mags1892
Post by mags1892 »
Pigment ink is best and youd need a transfer paper with a white backing for dark garments , Xpres and YOLO do decent ones.
Maruci
Post by Maruci »
Many thanks and sorry I wanst too clear, I do know I need a transfer paper :-). Can anyone recommend me a good brand of pigment ink for ricoh printers?
mags1892
Post by mags1892 »
Maruci;114093 wrote:Many thanks and sorry I wanst too clear, I do know I need a transfer paper :-). Can anyone recommend me a good brand of pigment ink for ricoh printers?
Im afraid youre pretty much stuck with OEM inks all the othr i tried are Epson inks rebadges, and Epson inks are thinner so wont work as well.
Maruci
Post by Maruci »
I will be printing onto yolo ss transfer paper using the OEM ink, do I need to do any color adjustment or change any color settings before printing? I am using photoshop elements; dont want to wast much paper trying ha ha ha
Nope we don't change a thing. Just use "Printer managers colour" and for us works a treat.
Maruci
Post by Maruci »
Thanks uk printed mugs
