Re: Where do I stand?
Posted: 24 Jul 2016, 21:40
by technick
My heat press has packed in (BMS DF20) - electrical fault, all lights on LCD is flickering and sometimes not even turning on. Tried with 4 different cables. The high pitched beeping sound is not flat also Does this fault typically get covered under warranty? It's only 6 months old. Cheers:)
Posted: 25 Jul 2016, 11:42
What did supplier say? I would expect at least 12 months on the press, usually the exception is with the element.
Posted: 25 Jul 2016, 12:20
by logobear
trade products don't have the same inplicit guarentee that consumer goods do ..... so you don't automatically get any warranty.
If you bought it from a reputable supplier I am confident you will be covered (thou probably not for transport either way) but if a cheapo off flea bay, you are almost certainly on your own.
Good luck!
Posted: 25 Jul 2016, 12:22
Sorry, I assumed you had bought new?
Posted: 25 Jul 2016, 12:25
by technick
BMS have been great. Scotty has sent out a new control unit today at no charge - cannot ask for better service than that, hopefully it resolves the issue:)
Posted: 25 Jul 2016, 12:40
by ArferMo
There ya go...... a quality supplier
