Mug images
pennz26
Re: Mug images
Post by pennz26 »
Hi everyone, me again haha
Now I have kind of sorted my sublimation issues I've had another come up. I've brought a few templates from mugshots and they print fine. I've tried to make myself a mug with an image I found on Google but the print has banding again, I thought it was due to it not being of good quality, so I tried a large version of the image and changed the size of image in photoshop to 300 dpi. Is it just because I'm using Google images? I wanted to put a game of thrones map on my mug instead of buying one.
Sent from my SM-G900F using Tapatalk
PeteO
Re: Mug images
Post by PeteO »
When you print the GoT Image you get banding, do you get banding with any other print (example one of Martins templates?)
If you dont could be a possible corrupt file from google?
pennz26
Re: Mug images
Post by pennz26 »
I have no problems with Martins templates at all its just the images I pull from google, is there a certain size or word I should use when searching
PeteO
Re: Mug images
Post by PeteO »
When searching google images there is a search filter across the top to filter for Large, Extra Large images
What about a photo you have taken, or image you already have?
Ravisteam
Re: Mug images
Post by Ravisteam »
I recon u need to check the print settings ..did you change the paper type to matt or what ever you normally use...bad images only make it blurry or pixelated not banding .
