Which Software for Dye Sub HELP NEEDED
Re: Which Software for Dye Sub HELP NEEDED
Hi People. I've been printing t shirts with pigment ink for a few years. (I use PagePlus DTP program for my graphics). What software should I use for Dye Sublimation?? I'd prefer not to spend hundreds of £ lol. Any advice will be much appreciated
- Has thanked: 11 times
- Been thanked: 9 times
Been asked a few times recently. In a nutshell, if you're using Sawgrass inks you can get the power driver software which allows you to print from any software.
If not..... Personally I prefer CorelDraw and sometimes Photoshop. You can buy older versions/educational versions cheaply that will now than do the job. If you want the latest versions, subscriptions are available to rent both monthly.
