Mug pictures for my website help please
Reading-Print
Re: Mug pictures for my website help please
Post by Reading-Print »
Hi all,
Just a quick question and possibly a very stupid one lol :wink: I have a cd full of images that can be put onto mugs most of them the customer can add pictures to them, I have them in psd format I don't upload the products to my website one of my friends has been doing it for me. But he is away on holiday, so my question is do I upload the psd file so then the customer can add the photo they want to it?
Damian
Using Ricoh Aficio A4 sublimation printer, Epson 1500w A3 sublimation printer, Xpres heat press, ST3042 3D sublimation machine http://www.readingprint.co.uk
wayupnorth
Post by wayupnorth »
It would be unusual to upload psd format, conversion to jpg is the normal route. Unless your site is setup for a program that allows you to add content you will need to edit the site directly and place the images in a suitable directory. Probably worth dropping your friend an email to find out the process, I'm sure he won't mind.....
Phil47
Post by Phil47 »
PSD is a Photoshop file, you will need to convert the files to use them on your website. I have used Zamzar to do this, search "Zamzar PSD to JPG" on your search engine for the link.
Reg
Post by Reg »
If your using PSD you must have software to open them so open them and save as Jpeg then put them on your site.
logobear
Post by logobear »
I would have thought you will need a file type that supports transparency so client can place their photo in the window?
In that case you should use .png files
Drew
Post by Drew »
You want to do it in the same way as you do your slate designs (I use the same programme for my online designs).
Upload image to website, and set the design area as that where the picture will go. Customer can then upload, and you'll get the placement and all correct.
wayupnorth
OP has not been back so probably not worth much effort... They obviously have a working system and I guess the friend will be back soon from holiday.
