Dye Sub Marrow Mugs?
Lauren
Re: Dye Sub Marrow Mugs?
Post by Lauren »
Hi everyone,
We currently use a Freesub ST210 to print Cambridge mugs but we have had an enquiry for Marrow mugs. Has anyone used the Freesub to produce these or can anyone recommend a press for these please? These are the mugs and they have a curved tapered shape so I'm concerned about getting good contact in the press we have - http://www.subliblanks.com/sublimation-marrow-mugs.
Thanks in advance for your help - we're shiny new to the Forum and its been a fantastic resource :)
Andrew
Post by Andrew »
You need and oven and wrap to get a decent print really. Even then the print area is 50mm on height at max and artwork has to be manipulated for the curve.
Lauren
Post by Lauren »
Oh I see, I thought there may have been an issue due to the curve. Thank you for your help :)
