Paper manufacturer temperature or mouse pad manufacturer temperature
Legari
Re: Paper manufacturer temperature or mouse pad manufacturer temperature
Post by Legari »
Hi! I have an issue, I'm using 2 kinds of paper right now, one not branded at all and Textprint-HR, I'm getting worse results with the Textprint, even if its supposed to be better, the blacks seems less black and I dont know if I should go with the paper indications or with the mouse pad ones, I'm doing 2 mins 180º right now.
I dont want to use the non branded paper anymore even if the colors are better because its curled and the printhead hits the sheet on the sides.
Reg
Post by Reg »
Your doing it to long cut your time to 65-75 sec,
Andrew
Post by Andrew »
As above, we would have a starting point of 60secs. 180c would be okay if it is Ricoh. Texprint has great ink release when using Epson, better than all others we find.
Legari
Post by Legari »
I find out that my Textprint releases way less ink with that time, I'm using Inktec Sublinova and the printer is the Epson 1500w.
Andrew
Post by Andrew »
You need more temp with Epson. 195c starting point. 60 seconds.
Legari
Post by Legari »
Trying with Textprint at 195c, 60 seconds, color still a bit duller than with the unbranded paper, should I go with higher temp or time? Thanks
Users browsing this forum: Google [Bot] and 17 guests
