I have a Ricoh SG 3110 with default driver and I'm having problems with image alignment, margins and bleed.
When I print a registration alignment-test it's perfect with even borders, but if I print a full page A4 picture it shifts to the left by an inch and I lose a lot of image at the top?
I've switched between regular and maximum in the "printable area" setting but it's the same with both (worse with maximum).
The A4 test image is located http://pixelperfect.com.au/files/PixelP ... b01_A4.jpg
Ricoh SG Registration Misaligned
