All round sublimation paper
Re: All round sublimation paper
I recently got some sublimation paper for my Ricoh SG3110 from Signzworld/UKcutter and it doesn't work. I noticed (after) it says "only for Epson". I have a few questions:
Will their "Ricoh" sublimation paper work better or is this just clever marketing?
Also, is there a universal sublimation paper that works well with Ricohs for mugs and t-shirts or will I need a hard-surface and a t-shirt specific paper?
Everyone says Trupix. Personally I use BMS own paper. It's no cheaper than trupix and I don't know if it's better or worse but I get great results so I've had no reason to change.
Hi Ucase, do you use it with a Ricoh Gel printer like the 3110? Is it good for fabric and mugs?Ucase Ltd;112436 wrote:Everyone says Trupix. Personally I use BMS own paper. It's no cheaper than trupix and I don't know if it's better or worse but I get great results so I've had no reason to change.
Hey Jerry,
Yes, I use the 3110 along with Sawgrass inks.
Missed the 2nd part of your question.Jerry;112444 wrote:Hi Ucase, do you use it with a Ricoh Gel printer like the 3110? Is it good for fabric and mugs?
It's fine on mugs (I use the pre-cut paper).
I don't do much fabric but I did use it on some babygro's and had no problem.
That may actually explain some of my issues with corners on phone cases. I don't do many now but may try trupix if I do more.technick;112453 wrote:BMS is great but does not work great with full wraps my end
