2 mug presses 2 problems....
hoverbug1
Re: 2 mug presses 2 problems....
Post by hoverbug1 »
Hi have a 5 in 1 combo blue mug press (signzworl) that I can not seem to attach the mug wrap attachment back onto the frame took it of because the bolt had bent so I purchased another similer size etc but just cant seem to turn the size adjustment without the other smaller bolt coming undone... Will take a photo and show...
Also purchased a another mug press from ebay get it home no instructions and it is digital control one, normal temp I use is 160 and 200secs but don't know how to change the settings on this and its going up to 400 something. so confused. Emailed the person to see if they could tell me the make or give me instructions... will take a photo of this too.
Please help got 60 mugs to do and no mug press that works.
Mugshots
Post by Mugshots »
Cant help with the 1st one but if its going up to 400 that's in F and you want C
First problem is you're buying cheap mug presses, in the long run (as you're finding out) this is false economy, 60 mugs should give you enough profit to buy a decent one so maybe start looking at something a little more substantial?
bigj2552
Post by bigj2552 »
Justin;111909 wrote:First problem is you're buying cheap mug presses, in the long run (as you're finding out) this is false economy, 60 mugs should give you enough profit to buy a decent one so maybe start looking at something a little more substantial?
hell even the wee cheapo @ £39 on ebay new would be better than any combo heat press
