Is there anybody out there who can print dye sub onto 2500mm wide polyester canvas DOUBLE SIDED? Actual dims of largest panel are 3700mm x 2500mm! It requires reverse face to be registered to front face.
I guess this won't be cheap!
Ultra wide format but that's not all . . . DOUBLE SIDED!
Brixhamboy
Re: Ultra wide format but that's not all . . . DOUBLE SIDED!
Canvas is the main product we sell and have been doing it since 2007. Firstly you can't get double sided canvas and the widest canvas available is 64" (1625mm). The only way you could do this is in parts and not double sided.
mags1892
You can do it with SOLVENT canvas or FLATBED UV printed registration isnt easy but ive done it before. If its for flags etc then the material generally is printed one side only as its a transluscent material .
