Replacement Parts
Vinylman
Re: Replacement Parts
Post by Vinylman »
Hi guys, I am looking for a replacement part for my mug press. It is the bit that you tighten or losen depending on the hug or bottle you are pressing. It doesn't seem long enough to get a tight fit for water bottles but is spot on for mugs.
Some advice would be great.
Cheers in advance:wink:
Think silicone sheet or rubber cut to size should allow you to do bottles, I'll try and find eBay link.
Vinylman
Post by Vinylman »
Cool, I have a teflon sheet but thought there would be a longer bolt that fits so I can do them all without change sleeves etc. If that makes sense
It still wouldn't tighten, you need to decrease the interior dimensions with a sheet.
logobear
Post by logobear »
silicon sheet mate.
there are old presses about designed for 11oz mugs - don't grip the 10oz - unless you find an engineer so sort I don't think you will find the mod
Vinylman
Post by Vinylman »
Perfect, thanks guys. So longer times then or higher temp with the sheet?
