Is it possible to print borderless on Ricoh?
Digital Designs
Re: Is it possible to print borderless on Ricoh?
Post by Digital Designs »
I have bought hd metal but it is about 2mm bigger than the printable area, just wondering does the Ricoh print borderless?
Ian Mc
Post by Ian Mc »
Nope - nor would it do you much good, as you still need an area of blank, unprinted space around the design to run your heat tape off on to.
PeteO
Post by PeteO »
You may have already done this, but apparently the Ricoh do not print their maximum area as default, wont offer borderless by may give you the 2mm you need
https://www.youtube.com/watch?v=q5eh44auY0E
logobear
Post by logobear »
it would mess up your machine doing full width as some would spill over and ink up the paper path
Yes, you can certainly go a little bigger (if you are using the SG7100DN) by buying the bypass add-on which allows up to A3+ size:
http://www.printerowners.co.uk/sublimat ... s-tray.htm
bfos
Post by bfos »
Does anyone know if there's at least a way to view where the print will cut off on print preview so you know how much you need to shrink it by?
Try set paper to letter and than print ;)
