Black colour turning Red in after mug heat press
customprinty
Re: Black colour turning Red in after mug heat press
Post by customprinty »
Hi Everyone,
iam in a hope to get a positive answer as i have just started selling sublimation mugs on ebay.
i bought all Brand new equipments
Ricoh SG311DN
Sublimation ink(unbranded Korean)
Sublimation Paper
Mug heat press MP105
as i started all black colours started turning red or brownish after heat press and i had to stop selling ATM.
i have tried warming the machine up first but it did not work.
i tired installing sawgrass power driver but couldnt setup as i using Gimp at the moment.
does anyone have any idea?
the print comes out well on paper but messes up after heatpress
Regards
You have noncolour correction software and or you everheating your mugs.
Get Canvas & Sublimation
Post by Get Canvas & Sublimation »
Sounds like your cooking it too long to me. Whats your time/tempratures?
Sent from my SM-G900F using Tapatalk
customprinty
Hi Paul
thanks for your reply, can you kindly explain how will i get coloure correction software .
i also tried using lower temprature but the image comes out completely faded
Regards
customprinty
my mug press have automatic temprature and iam using 200 seconds to cook.
i tried more and less time but it doesnt work.
Adobe photoshop with correct icc profile or CORRECT powerdriver for your system.
spendingas little as possible wont get you to far i am affraid :(
so you will need to fork out little bit more for quality results.
I dont really want to type to much as i am onnmy phone. But here is copy and paste from my website about when you need colour correction profile:
Have you ever struggled to print accurate colours onto a mug, or other item?
Blacks may print brown, or purple; yellow may print as green; and reds could be pink or orange. If this sounds familiar, then you’re not alone.
To print the correct colours, your printer needs to know how to print 16.7 million colours from its inkset of just 4 or 6 colours. That’s where a colour correction profile can help. A colour correction profile (often called an “ICC profile”) is created by comparing the colours that your printer actually prints against what they should be, and then providing a list of “corrections” to your printer through your software or printer driver.You may already have an ICC profile supplied by your ink supplier, but they can only provide a “best guess” correction using their own printer. Your printer is different. All printers are manufactured to within tolerances and one profile is unable to be accurate for all such variations in manufacture.To achieve the very best colour accuracy, you need a colour correction profile that’s matched to your printer, your inkset, and your paper. That’s where we can help.Use our easy 4-step process!1. Place your order online.2. You’ll receive three colour charts by email. Print these charts using the recommended settings and post them to us.3. We will scan the charts using an advanced spectrometer to accurately measure the colours that your set-up is producing. From this we will create your custom colour-correction profile that’s unique to your printer, inkset, and paper.4. Check your email for your brand new colour-correction profile complete with easy instructions for using it in Adobe Photoshop or similar.That’s
it!This service is suitable for any printer/ink system, including dye, pigment, or dye-sublimation.
mags1892
Post by mags1892 »
you need to press to a suitable substrate too as reading the sub paper wont give a good profile it need to be pressed onto something similar to what youre subbing to.
oh i know that!
