I've done some searching around, and can't seem to find a standard size plastic ID card blank.
Xpres do a metal, but any ID cards I have seen have been plastic. Seems they're available for desktop ID printers, not sure it'll work with the heat from the press?
ID card blank supplier
Get Canvas & Sublimation
Re: ID card blank supplier
Plastic ones will melt in a heat press. Only thing i can reccomend is a metal cut to size.
Sent from my SM-G900F using Tapatalk
Cheers!
That solves that question! Wish I had put them on my order from Xpres now!
Saves you having to scrape off melted plastic from your heat press, which is no fun i can tell you
