I came across a video on you tube today I believe was from Paul on here. He mentioned how flexi does not cut out jpeg or similar files. So how do i cut out a jpeg image i have on flexi? Does it need to be converted ? How do i do it free?
Dave
Flexistarter 10 help
Dave271069
Re: Flexistarter 10 help
you can. but you will need cutline. To create cutline you will need vector software like corel draw or illustrator.
here is one of the ways of doing it.
Dave271069
Thanks PAUL, after a few days ive started to work it out. using the Smurf cutter HWQ630 im slowly getting there, one more question, when cutting hot flex vinyl or most clothing vinyls what would you set the speed and force at?
DAVE
DAVE
This is all depends how far is your blade out. Do few cutter tests and you will find sweet spot for your cutter
