Initial setup (Epson)
8800gto
Re: Initial setup (Epson)
Post by 8800gto »
Hi all,
I am currently in a process of installing a Epson xp (422) and I was wondering during the initial setup do I use the sub (ink) for the setup process or the original ink instead.
I know this might be a straight forward response but I want to make sure, since I couldn't really get a concrete answer using search on the forums.
Any information would be helpful
Thank you in advance!
mags1892
Post by mags1892 »
SUB ink else youll be wasting ink and possibly contaminating the sub ink.
8800gto
Post by 8800gto »
ok, so S should ignore the oem inks that came with the printer? just thought I needed to install the oem inks first for the nozzle check.
Thank you for the response!
mags1892
Post by mags1892 »
8800gto;109496 wrote:ok, so S should ignore the oem inks that came with the printer? just thought I needed to install the oem inks first for the nozzle check.
no you can nozzle check with sublimation inks the Inks i supply are chemically similar to epson pigment but even then id suggest deionized water
