Hi to all.
I am just starting out and currently using a 2nd hand 31cm x 31cm Chinese made flat heat press. I am looking at getting a 38 x 38cm or maybe slightly bigger press so I can print larger images on a wider range of items. I have read through the threads on here but have not been able to find any threads on the best budget presses. I have read the buy cheap buy twice thing a few times and while I understand and appreciate that I can't afford to spend £600+ at the moment. Can anyone recommend good reliable 38 x 38cm presses at the lower end of the market. I have seen some on ebay from coralgraph and signzworld for just over £100 but that seems very cheap.
Spitzy
Best budget 38 x 38 flat heat press
Re: Best budget 38 x 38 flat heat press
I thought I could experiment with a few products on a budget press, but they were so poorly made, I was wasting time and money. Wait until you have enough to consider one of these presses. Basic, but much better than budget.
http://www.targettransfers.com/p/013656 ... ic-28x38cm £420
http://www.targettransfers.com/p/110877 ... ic-38x38cm £540
http://www.themagictouch.co.uk/acatalog ... Press.html £719
