cameo 2
bigj2552
Re: cameo 2
Post by bigj2552 »
can it be used to cut out jet soft pro film/paper or similar ?
so it removes any square border around the image/s or text
bigj2552
Re: cameo 2
Post by bigj2552 »
im will be dammed if i can get this machine to find the reg marks.
every single time registration failed...
cameo 2 with version 3 software.
is it software problem ??
scotty44
Re: cameo 2
Post by scotty44 »
Not used the reg marks for ages but if I remember right make sure you bring them in about 25/30mm from the top and side, to close to the edge it never worked, I found setting it up manually worked better for me!
Re: cameo 2
make sure you sheet is dead on stright in came. if its not then your registration search will fail.
bigj2552
Re: cameo 2
Post by bigj2552 »
its dead straight and lined up with the wee line bit on the left ;(
bigj2552
Re: cameo 2
Post by bigj2552 »
right....
got it to find reg marks.....:wink:
it start to do the cutting .....then stops, says - status - syncing
whats it syncing ????...it not doing anything now, just sitting there syncing :confused:
this brings back memories of the first cameo i had....
check back the posts of mine on here from 2012 lol....:rolleyes: hair pulling stuff at times
da-ja-vu
Re: cameo 2
bufforing problem. similar problem i had with my Craft Robo.
bigj2552
Re: cameo 2
Post by bigj2552 »
finally got it.....
old memories dont die off lol
just need to show the girls now :tongue:
and a few more days of practice and we good to go
bigj2552
Re: cameo 2
Post by bigj2552 »
only way i got this to work right was to revert back to an older version of the software...
V3 of the cameo software throws up SYNCING issues every single time..
yet, used the v2.7 software, everything works as it should.
so....
is there software borked then ?
cause v2.7 works no bother here
