Removing a background image
Kaz
Re: Removing a background image
Post by Kaz »
I've got a piccy that I need to remove the background from.
I've tried using the lasso tool in photoshop, but it's not very accurate.
I've got coreldraw X4, Inkscape and photoshop. Which would be the best one to use to remove the background image?
NASH
Post by NASH »
have you tried the magnetic lasso
Kaz
Post by Kaz »
No, but I shall go and locate it and try it now
Magnetic lasso should do the vast amount of the work and then you can blow up the image to fine tune the erasing with the eraser tool.
Kaz
Post by Kaz »
Well, it seems to have worked :D
Only problem is, I can't seem to take the background away on part of it, as it's through a window.
any ideas?
Attached piccys
Kaz
Post by Kaz »
Don't need to worry now about the windscreen, the client is very happy with it as is :D
Kaz wrote:I've tried using the lasso tool in photoshop, but it's not very accurate.
lasso is only accurate as your hand is :)
Photoshop is best software for this job. you can also use mask to make sellection. :geek:
Kaz
Post by Kaz »
I noticed that Paul :lol:
Now I know how to use the magnetic lasso, I will practice with the mask tool another time :)
swimwivsquid
Post by swimwivsquid »
Also try the pen tool. Much easier than the lassoo when you get the hang of it.
Kaz
Post by Kaz »
Thanks Richard, will try that the next time I have to do one :)
Users browsing this forum: Baidu [Spider] and 3 guests
