I've just got some samples of MDP Cool Flex with the sparkly designs.
ANybody else use this on a Craft Robo ? No matter which blade I use, and even with the highest settings I still can't get the stuff to cut correctly. It keeps leaving little bits uncut.
Any ideas ?
MDP Cool Flex
Re: MDP Cool Flex
I use a similar version of it from xpres, very difficult on my robo and only suitable for larger designs, I definately cant cut small lettering. I cut on the thickes setting, pink blabe (used to use the yellow) and slow it down but it still is abit iffy sometimes.
This was one of the first samples i tried on my robo and it has alway been this way, maybe there is just not enough pressure on the blade. It would be interesting if anyone else can cut it easily with a robo.
Re: MDP Cool Flex
mines not too bad on the blue blade but as u said ..on small lettering its a bit faddy ...i tend to have to hold down certain bits while weeding so that they come off the sheet but not really a big problem.I just thought it was normal ...lol
Re: MDP Cool Flex
I've got a load of the MDP cool flex with sparkly designs upstairs, and my cutter cuts it no problem
But then again, it's a big monstrous machine, not a craft robo
