ST-3042 broken temp gauge?
3D Sublimation
spartagates
Re: ST-3042 broken temp gauge?
Post by spartagates »
Hi Guys,
Quick question; have set and trying to get this vacuum pump press working. Is it normal during turning on and first heating for the temp gauge to say 00? Have attached pic. Seems to be heating up and fans spinning, but after 5 mins or so still sitting at 00 and very hot and trips out the main RCD.
Thanks!
vB_ID:3797
vB_ID:3797
spartagates
Just in case anyone does have the same problem; it was broken; unit now replaced and working fine :)
It was probably the thermostat.
