Re: T shirt press
Posted: 11 Dec 2015, 14:18
by Kev1
I have recently brought a 5 in 1 press. The press works fine, after doing about 6 t shirts one after the other I noticed a "shadow" of the previous t shirt on the t shirt I was pressing. I turned the press off and cleaned the top plate but the next t shirt was the same. What can I do to stop this? Thanks Kev
Re: T shirt press
Posted: 11 Dec 2015, 14:59
by wayupnorth
Cheap greaseproof/parchment paper from eBay/pound shops between dyesub paper and top plate, I change this after every pressing. If you do front & back print use a sheet on the bottom as well, part of the image will transfer to the plate during the second press. Adds a few pence to each garment but much cheaper than losing one, discovered this the hard way....
Re: T shirt press
Posted: 11 Dec 2015, 16:34
by Kev1
Thanks for that I knew it would be something simple. Where do you get your sublimation bits from? Mine are quite expensive. I don't sell them its to advertise my own business (electrical testing).
Re: T shirt press
Posted: 11 Dec 2015, 16:40
by wayupnorth
The usual suspects in the "Suppliers" section of this forum plus BMS. Worth getting premium membership on here as it will pay for itself with your first order.
Re: T shirt press
Posted: 13 Dec 2015, 06:15
by Kev1
Thanks wayupnorth, will look into that. Kev
Re: T shirt press
Posted: 14 Dec 2015, 09:34
by mags1892
Teflon sheets I have an entire roll here if you need some cuts
Re: T shirt press
Posted: 14 Dec 2015, 20:58
by Kev1
Mags1892, just picked up 10 metres of grease proof paper to try. Ill let you know! Cheers Kev
