what size element?
Mugshots
Re: what size element?
Post by Mugshots »
Is needed for the cola can money boxes and small flasks which are the same diameter?
Smallest I have is a 6oz and its not quite small enough
Reg
Post by Reg »
Use a silicon wrap with it
Mugshots
Post by Mugshots »
Where would I get one to fit please? Does the silicon then heat up enough? Do I have to use higher temperatures?
Reg
Post by Reg »
Most suppliers sell them or buy a silicon backing sheet of ebay and cut size I think it was Paul put a link to the ebay one on here a while they are slightly thinner but it works out cheaper and you get more than one out of it,you may have to increase your time and temp slightly you'll have to experiment on that as all presses vary
Mugshots
Post by Mugshots »
Just bought some silicone sheet :biggrin:
