Hi all, I have searched on here but can't find the info I need.
I had an old Epson sx445w printer which had normal inks in, I invested in a ciss system and a set of pigment inks so to print Tshirt transfers, I'm due to set it all up tomorrow and was wondering do I have to flush my printer out before using the new inks and ciss system, if so how? I'm using pigment inks and presuming the original inks were pigment based so I'm not sure if I need to or not
Best regards
Carl
Sent from my A0001 using Tapatalk
Printer flushing
- abacus1983
mags1892
Re: Printer flushing
Depends if theyre chemically compatible if cheap chinese pigment then they wont have a lot of pigment inthem and certainly wont be chmically the same as oem.
- abacus1983
