Cushion Covers getting stain marks after printed
Re: Cushion Covers getting stain marks after printed
Hi guys how you print cushion covers with white both sides (Sublimation ) .I get odd stain marks / spots on unprinted areas ..Teflon sheet doest stop it ..Please share your solutions to this ..Thanks in advance ..
Hi Ravisteam
To prevent dye going through to the back layer of your cushion put a piece print paper between the two layers. Also if you are using your Teflon sheet direct on top of your cushion you really need to clean it before using it again as any dye that is on the Teflon sheet will transfer onto the next thing you print. We tend to use a sheet of craft paper on top of what we print and replace it with a new sheet when needed.
Cheers
Kath
Kath
Hi Kath , thanks for the advice ..So I need to have new craft paper or 2 every time I pressed a cushion right ..??..Where do you buy the craft paper from and do they come in A3 size ..Thanks for your info BTW.....
Hi Ravisteam, yes it is best to use a new piece every time. It does seem a it wasteful but it helps keep the dye from getting transferred where you don't want it.
I don't have the link handy, but we normally buy it off eBay by the roll.
Here is the link to what we last bought
http://www.ebay.co.uk/itm/20m-600mm-Pur ... 588ba8e03e
Cheers
Kath
Kath
- mrs maggot
you could always pop into your local chip shop and see if they will sell you a pack of their paper, its about £8/£10 a pack from the wholesalers
