ink change SG 3110DN
arti
Re: ink change SG 3110DN
Post by arti »
Quick question
Ricoh 3110dn My ink cartridge are over half full ( Sawgrass Sublijet ) can I remove these and reuse them in a new SG 3110dn, will they work or will I have to get new one's to comply with the new 3110.
When you put carts into a new machine it 'charges' the lines and uses a huge amount to do so. If you'e lucky they'll be enough but will quickly run out. I'm really not sure if you can put part used carts into a new machine and if it will recognise them as being part used. I did once ask SG a similar question and they said they always recommend new carts....but they would, wouldn't they! Personally I would go with new ones unless I was sure there was enough in to fill the lines and that they would be recognised properly.
