Newbie from Swansea
Take a minute to introduce yourself. We won't bite!
Hazewithin
Re: Newbie from Swansea
Post by Hazewithin »
Hello all,
I am Katie :) I have just bought an 8 in 1 heat press & now I need to buy everything else to get me going. See extremely a Newbie.
I have probably bitten off more than I can chew. So I shall be on here most the night looking for advice the you have given others.
jennywren
Post by jennywren »
Welcome when I'm learning something new I go through all the post in that subject and I copy and paste into works, what ever I thing is relevant to me. this way is saves you hours of going back when looking when you have a problem. When reading the one thing that will keep getting repeated is is ink, time and temp and paper. There is somewhere on this site templates. It does help before you print on a mug or what ever your doing, I printed it on normal paper and fitted it around the mug to see if it would fit. I even have a template now with markers to show where to lay three mugs and the markers show when I cut so that the they are all the same size. I then put the paper on the edge of the bottom of the mug and that's how I know that if I'm doing a batch of mugs they are all going to be in the same place. Hope that makes sense and good luck in your venture.
Has thanked: 11 times
Hi Katie, welcome to the forum and also the wonderful world of sublimation! ;-)
DSF Admin
Hazewithin
Thank you Jenny
ISub-Sarah
Post by ISub-Sarah »
Hi Katie,
Welcome to the forum and good luck with your new venture!
Kind regards
Sarah
