Change Size of Design for Shirt Sizes?
Stitch Up
Re: Change Size of Design for Shirt Sizes?
Post by Stitch Up »
Quick basic question guys,
I've been asked to produce 20 + shirts in sizes varying from small to xlarge.
There is just one line of text on the back across the shoulders.
Would you keep the width of the text the same for all shirts or wider for the xlarge shirts and less wide for small shirts?
Cheers
John
jennywren
Post by jennywren »
We go wider for l xl shirts, both the text same size, and on the small and medium it not so wide but the text same size, Hope that made sense.. on a two xl much larger and wider.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Just to add to the confusion.....I print the same size.
Not very helpful am I!
Janners
jennywren
Post by jennywren »
when I print. I do the text separate then tape it to the design.
Earl Smith
Post by Earl Smith »
Same size for all here ( 28cm wide) too if its only mens t.shirts. Maybe go bigger for 3xl plus. I usually point out to customers that the design fits from Nipple to Nipple.
Womans t.shirts, 25cm wide or down to 20cm for the really small.
Ps; I only wrote this because I wanted to write Nipple. :-) I go back in my box now.
Quinsfan
Post by Quinsfan »
Earl
I try to do the nipple to nipple measurement for the hen do t shirts but the court orders are mounting up, is there another way? :biggrin:
