Looking to press some logos down sleeves of hoodies with our Adkins Beta Maxi and think a form of cushioning would be required so I wondered if anyone had experience of what teflon pillow makes or/and thickness sizes will work with this make of press, space between the plates is fairly limited. I've seen this set at xpres which includes a sleeve shape one as well as other size squares which could be useful but not sure how thick they are http://www.xpres.co.uk/p-9018-textile-t ... xpres.aspx
Mark
Teflon pillows
Re: Teflon pillows
Anyone got any suggestions on this if they haven't used teflon pillows??? I used a doubled up piece of cardboard in the end for the sample sleeve I did which prevented the seam showing and it came out okay but maybe not a long term solution. With the adkins swing press gap being quite slim its the height of a teflon pillow than concerns me as I've not seen or used one, the silicon foam A4 I have from ebay is quite dense but fits as its slim and is good for chests but need longer than A4 for a sleeve else I could have chopped it in half.
