I wonder if anyone has experienced the problem when textile vinyl is pressed to clothing and white peeks through at the cut edges?
Here's an example where I'd printed to an Xpres vinyl - Xpres XP3030 & 3031 Easy Print Textile 50cm Wide.
I clearly can't let this hit the streets and I doubt whether any customer would accept it! So, what's the solution?
Cheers
John
