I have an image in coreldraw x7 which I have a cutline around (simple circle shape). I add reg marks and send to cutter. The problem I have is when I cut it doesn't cut where I expect. It is only just off where it should be but I don't know why!
Any help would be appreciated.
Keith
Graphtec CE6000-40 problem
Re: Graphtec CE6000-40 problem
are you doint the 3 point registration with the tip of the cutter blade?
do you have the MEDIA IN THE CORRECT WAY ROUND?
P
P
yes to all of the above. It turned out my cutter was set to rotate! Only had it 2 weeks & not been in the menu until speaking to Graphtec today. Cutting everything perfect now.....loving the CE6000-40logobear;104274 wrote:are you doint the 3 point registration with the tip of the cutter blade?
P
mags1892
You can run a registration calibration on these , Im a graphtec reseller in newcastle. GLad youre sorted theyre fantastic machines.
