Teflon pillow with Adkins swing away
kermit
Re: Teflon pillow with Adkins swing away
Post by kermit »
Can Teflon pillows be used with the Adkins swing away heat press
ArferMo
Post by ArferMo »
you are limited with space to about 20mm
Has thanked: 11 times
I made a new lower platen for mine which added much needed space but you're still very limited I'm afraid, it's one of the few drawbacks with Adkins.
kermit
Post by kermit »
Thanks for the replies guys.
Justin, how did you make a new one?
KathG
Post by KathG »
Hi Kermit, I know there is not a great deal of room between the platens on the Beta Maxi, but we use the Teflon pillows or foam in ours with no problems at all.
One example is we are putting chest logos on a high poly content polos and use a 20mm X 20mm platen. My son always uses the Teflon pillow to soften the edges of the platen as their is no Teflon cover for that size.
Cheers
Kath
kermit
Post by kermit »
KathG;103959 wrote:Hi Kermit, I know there is not a great deal of room between the platens on the Beta Maxi, but we use the Teflon pillows or foam in ours with no problems at all.
thanks Kath. I've got a pillow now so I will have a go with it
Keith
